Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-10-2008, 09:40 AM
hooked8's Avatar
hooked8 hooked8 is offline
Unhappy Fuel cell foam breaking up?
Guys - we have one car that we can't get running reliably. (GTRA) - It always starts fine, we've timed it at 13degrees, checked all the basics - swapped out ECU, fuel pump, filter - good plugs wires - but it wil go off song after maybe 1-4 laps...runs fine then just starts breaking up...one time we had a renter who stayed out there and it heated up to 235....but didn't boil over....just can't get it settled down....Anyone discover that their fuel cell is breaking up and clogging filters, lines or injectors? These cells have to have been sitting around for a long time...we have Texas cars - serial numbers in the 40's....david
Old 03-10-2008, 02:04 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Fuel cell foam breaking up?
Hmmm... I've never had a fuel cell in a car before, but did notice that my foam looks out of whack. I dont' know what it's supposed to look like though.... I did notice that when I ran the car a bit low on gas it would cut out on hard right hand turns.
Anyone have a shot of what the fuel cell foam should look like in the proper position?
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 03-10-2008, 02:08 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Are you getting any alarms on the dash? When you return to the paddock after a run, the dash will go into tell tale mode. It will show you the minimum fuel pressure for the outing. It should be easy to confirm or eleminate fuel that way. If the cell foam is breaking up, you should see foam in the filter.
Have you hooked up a code reader to it?
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 03-10-2008, 02:15 PM
panoz302 panoz302 is offline
mine was doing the same as it turned out the spark plug boots where getting too hot and deteriorating and arching on the headers, as the ywhere too close. I do not think the foam would get past the screen on the pickup and it should not clog anything, but you can flush the tank with water and then disassemble it. If the foam broke down after time I think fuel safe would have info. on its shelf life.
Old 03-10-2008, 05:10 PM
hooked8's Avatar
Good comments guys...will check these out - yes, it was low on pressure...
Old 03-13-2008, 12:47 PM
wirewheel99 wirewheel99 is offline
We just fixed one of our WC cars with a similar problem..3-4 laps then a loss of power..It turns out the MAS Mass Airflow Sensor was very dirty....
Lots of rubber and dirt thrown up into the airfilter then the MAS got dirty..worth a quick look
James Redman
link removed - unauthorized advertising
Old 03-13-2008, 09:37 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Yup. Another good suggestion.
Jerry
1999 Panoz GT-RA
Old 03-14-2008, 01:20 AM
hooked8's Avatar
Man - you guys are good...thanks for the input - we WILL check that out immediately...on all our cars...also - we had a former Champ Car team mechanic drive one of our cars...he had fun...but saw we were struggling with one of the others...he just observed that the fuel pump should never be above the cell..making it a sucker...it should be on or below the level of the tank...making it a pusher...make sense??
