Old 03-10-2008, 08:14 AM
smeltdan smeltdan is offline
starting problems
I just put a new fuel pump and fuel filter in 2000 4.3l bravada and now it won't stay started. I'm sure I hear the pump turn on and off. It will start running at high rpm for a second or two then will start sputtering then shut off. Will start right up but will sputter then die, if press on gas pedal will stay running. When I manually held the throttle open, after many attempts to start, there was smoke. I sure could use some ideas it's been a week!
Old 03-12-2008, 11:53 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: starting problems
It likely needs to be scanned so the computer can help diagnose the problem.
