Old 03-10-2008, 08:24 AM
glss421 glss421 is offline
Sputter under heavy load
I have a 99 GTP with 88k. Intermittently when the car is under heavy load, (flooring it from a stop usually), it seems to sputter, or skip a beat if you will, at about half boost. I changed the plugs and wires and the problem did improve but it's still occuring. Any advice?
Old 03-10-2008, 10:26 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Sputter under heavy load
check fuel pressure yet?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-10-2008, 10:54 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Fuel filter also
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-10-2008, 11:54 AM
No, how do I check the fuel pressure?
Old 03-10-2008, 12:01 PM
Headnsouth's Avatar
Cuts Out, Misses
Checks
Action
DEFINITION: Steady pulsation or jerking that follows engine speed, usually more pronounced as engine load increases.
Preliminary
• Refer to Powertrain On Board Diagnostic (OBD) System Check .
• Refer to Intermittent Conditions .
• Search for bulletins.
Fuel System
• Check system fuel pressure. Refer to Fuel System Pressure Test .
• Check the fuel injectors. Refer to Fuel Injector Balance Test , Fuel Injector Solenoid Coil Test - Engine Coolant Temperature Between 10-35 Degrees C (50-95 Degrees F) or Fuel Injector Solenoid Coil Test - Engine Coolant Temperature Outside 10-35 Degrees C (50-95 Degrees F) .
• Check for contaminated fuel. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
• Check items which can cause an engine to run rich (long term fuel trim significantly in the negative range). Refer to Diagnostic Aids for DTC P0172.
• Check items that can cause an engine to run lean (long term fuel trim significantly in the positive range). Refer to Diagnostic Aids for DTC P0171.
• Check for fuel in the Fuel Pressure Regulator vacuum hose.
Sensor/System
Check for conditions which cause an incorrect idle speed.
• Throttle body tampering, excessive deposits, or damage. Refer to Fuel Metering System Component Description .
• Restricted air intake system.
• Large vacuum leak.
Check the TP Sensor and related circuit wiring. Refer to DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage .
Check the EGR system for proper operation. Refer to Exhaust Gas Recirculation (EGR) System Description .
Check the PCV Valve for proper operation. Refer to Crankcase Ventilation System Description .
Check the Transaxle Range Switch input with the vehicle in drive and the gear selector in drive or overdrive.
Check the following for damage:
• Bent harmonic balancer interrupter rings.
• Damaged Crankshaft Position Sensor.
Ignition System
• Check for proper ignition voltage output using the following steps:
- Clip the J 26792 spark tester to engine ground.
- Connect one end of a spark plug wire to the J 26792 spark tester; leave the other end of the spark plug wire to the coil being tested.
- Connect one end of another spark plug wire to the other coil tower; connect the other end of the spark plug wire to ground.
- Crank the engine while observing the J 26792 spark tester; a crisp blue spark should be observed.
- Repeat the above steps for each coil.
• If adequate spark is not present at the coil(s), check for the following conditions:
- Coil(s) -- Cracks, carbon tracking/arcing, or a resistance value outside the specified range.
Coil Resistance
5000 - 7000 ohms (5K - 7K ohms)
- Spark Plug wires -- Signs of arcing/cross firing, cracks, carbon tracking, plug boot damage, pinched, improper routing, or a resistance value outside the specified range.
Spark Plug Wire Resistance
600ohms per foot (1 968ohms per meter).
Important: : Spraying the secondary ignition wires with a light mist of water may help locate an intermittent problem. Ignition components will arc to ground when a secondary component is faulty.
- Defective module.
- Ignition System Wiring -- Loose ignition module feed or ground connection, or damaged system wiring.
• Remove spark plugs and check for the following:
- Fouled plugs
- Cracks
- Wear
- Improper gap
- Burned or damaged electrodes
- Improper heat range or reach
• If spark plugs are gas or oil fouled, the cause of the fouling must be determined before replacing the spark plugs.
• Check for the following intermittent ignition system conditions:
- Intermittent CKP 24X Signal.
- Intermittent ignition feed circuit or sensor ground circuit to the crankshaft position sensor or the camshaft position sensor.
- Intermittent 3X reference signal.
- Intermittent camshaft position signal
Engine Mechanical
• Check engine mechanical for the following:
- Check compression. Refer to
- Sticking or leaking valves.
- Worn camshaft lobe(s).
- Valve timing.
- Bent push rods.
- Worn rocker arms.
- Broken valve springs.
- Excessive oil in combustion chamber-Leaking valve seals.
- Low cylinder compression.
• For incorrect basic engine parts. Inspect the following:
- Camshaft
- Cylinder heads
- Pistons, etc.
• Refer to Base Engine Misfire Diagnosis .
Additional Checks
• Check exhaust system for possible restrictions. Check for the following:
- Inspect exhaust system for damaged or collapsed pipes.
- Inspect mufflers for heat distress or possible internal failure.
- For possible plugged Three-Way catalytic converter. Refer to Restricted Exhaust System Check and Exhaust Leakage - Not OBD II .
• An engine miss condition can be caused by Electromagnetic Interference (EMI) on the reference circuit. EMI can usually be detected by monitoring engine RPM with a scan tool. A sudden increase in RPM with little change in actual engine RPM change, indicates EMI is present. If a problem exists, check routing of secondary ignition wires, high voltage components (Near Ignition Control circuits).
• Check for intake and exhaust manifold passages for casting flash. Refer to Base Engine Misfire Diagnosis .
• Check for faulty motor mounts. Refer to Base Engine Misfire Diagnosis .
03 GMC Sierra 100k
