electrical help
So I was trying to install my aftermarket stereo and I guess the gorund wire accidentally touched an another wire and sparked up. I wired everything up correclty but nothing worked. Stereo fuse is fine, and the stereo fuse under the dash is fine as well..
Anything you guys think that could be wrong... I was thinking of checking the rest of the fuses/ or replacing them if anything is wrong. But all my tail lights, head lights, brakes lights etc. work so Id assume there is nothing wrong with the rest of them. Would something reset or anything if i remove a fuse to check it? I been over it all day and cant seem to figure out why the Stereo wont power on. I was thinking of having all the wires replaced and redone, are there any kits made for the 80's caprice to re wire everything? |
Re: electrical help
Try powering up the radio directly from a power source.
03 GMC Sierra 100k 05 Infiniti G35 150K 10 Mazda 3 Hatchback 110K 16 Infiniti Q50 Red Sport 34K |
Re: electrical help
If you simply twisted the wires together and taped them up, that makes for a potentially weak and unreliable connection. I always solder connections and insulate them with heat shrink tubing, but crimp connectors or small wire nuts and some electrical tape would work. Anyway, I like the suggestion above to "bench" test the head unit by powering it on using a direct source of power and ground. This will eliminate the option that the unit is fried if it powers on.
Re: electrical help
Make sure the wire marked battery (sometimes orange or yellow) is properly loaded to a point on the fusebox that always has power, and the 12v wire (usually red) is on an IGN source at the fusebox, and that both fuses are good (there are fuses on both bat and 12v lines on most aftermarket radios).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: electrical help
I just hooked the deck up to the car battery and the HU turned on, all fuses are good none are blown out. I have no idea whats up.
Re: electrical help
Anyone?
I just ordered an wiring harness so I will see what happends from there. I'm just no understanding is all the fuses are good. I wired the Stereo to the factory harness real good and no power to the Stereo. But when I hooked it to the car battery it comes on. |
Re: electrical help
your ground point in the car is not grounded or your + (hot) wire in the car has a open point meaning you must go check on the + wire with a test light to find the power outage. good luck 463
Re: electrical help
If you have a multi meter do a continuity check on your fuses. It may look ok but maybe blown. Also check for power at the tie in and work your way back. Check your grounds to.
Re: electrical help
Is there another fuse box under the hood? If so where?
Re: electrical help
Not sure of a location but it'll most likely be a black box near the firewall or fenders.
