Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-09-2008, 09:23 PM
accutech accutech is offline
Unhappy sliding doors not working
hi
i have a 1998 pontiac transport with a power sliding door problem it will not power slide open or close and if i click the inside button to close or open nothing happens and if i use the remote control it clicks under the passanger side dashe i checked it its the relay clicking and i have a problem as well with the locks it only unlocks from the switch inside and it doesnt lock but it will work from the remote control lock and unlock please if anyone knows whats going on or had that problem let me know thanks
Old 03-10-2008, 05:58 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: sliding doors not working
Reinitialization of the Power Sliding Door
Important: Before performing the PSD re-initialization procedure, inspect for DTCs by performing the Diagnostic Mode 1. Refer to Diagnostic Modes.
Perform the PSD re-initialization procedure when any of the following conditions exist:
• The PSD is inoperative.
• The vehicle battery is reconnected after being disconnected.
• The vehicle battery is recharged due to a low or discharged battery condition.
• The RADIO fuse (located in the underhood accessory wiring junction block) is reinstalled or replaced.
• You exit any of the Diagnostic Modes. Refer to Diagnostic Information and Procedures for more information.
Use the following procedure in order to re-initialize the PSD:
Enable the overhead console PSD lockout switch (pressed position).
Manually open the sliding door completely.
Manually close and fully latch the sliding door.
Remove the RADIO fuse for 30 seconds.
Reinstall the RADIO fuse.
Wait 10 seconds.
Disable the PSD lockout switch (released position).
Press and release the PSD open/close switch (overhead console or B-pillar). Allow the PSD to open completely.
Press and release the PSD open/close switch.
Repeat Step 8 and Step 9. Inspect for proper PSD operation.
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-10-2008, 01:10 PM
Smile Re: sliding doors not working
thank you very much its up and runing
Old 03-10-2008, 01:24 PM
Headnsouth's Avatar
03 GMC Sierra 100k
