Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-09-2008, 07:51 PM
clhuff clhuff is offline
all kinds of problems
okk just got my tsi back today pretty much the bottom end was rebuilt
so i was trying to break it in
problem 1. when you shift car bogs horribly bad, car has no take off what so ever every once in a while it would jerk and kinda take off just as if i shifted down but other then that it feels like im driving a lawn mower down the road
problem 2. some kind of rattling noise coming from the head then had starting problems it would take a while of turning over for it to start then it stalled at a stop light while clutch was engaged, then the car wouldnt even turn over even when i hooked the jumper cables up this is a brand new optima battery and the dam car wasnt even turning over i thought the engine was done at this point but i let it sit for few hours tried it for the hell of it and it turned over a bit but that was it
what is going on?
95 talon tsi awd
99 oldsmobile intrigue (dd)
Old 03-25-2008, 03:41 AM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: all kinds of problems
could be many things, most likely a boost leak. if you have a turbo.
Old 03-25-2008, 07:38 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Wow vince haven't heard anything from you in a long time.
Do a boost leak test and see what you find. Rattleing in the head doesn't sound good. Might want to take it back to the shop that worked on it and have them check it out.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-25-2008, 03:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I'd say check the timing first and foremost, don't want to be bending any valves.
95 Talon TSI AWD
97 Eclipse GST
Old 03-25-2008, 07:07 PM
well this is whats going on wastegate isnt working and the rattling noise is coming form the 1st cylinder I think its the valve guides it idles fine
my solution 6 bolt is going in and I have a 14b and another wastegate that is going on as well so that should take care of everything hopefully
