Slight vaccum issue
I notice when i set the AC controls to the "Economy Vent" setting, only the dash vents will blow out, and i notice if i stomp on the gas then the dash ones will open up and start working. i remember my 1988 caprice used to do this as well. it only does it on the economy setting.
2006 Chevy Cobalt LS |
Re: Slight vaccum issue
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
I had that issue right when i bought my 83, that little black wheel was the first thing i replaced and it fixed the hissing noise, i think the problem im having now is beyond that little black wheel though. when i had my other caprice someone told me it was the vacuum pump
under the hood is a vacuum ball soft ball sized going to it is a vacuum line and a check valve to trap vacuum in this ball.... the trapped vacuum goes to a/c controller under dash... when engine is off this ball should hold vacuum if not find leak......... |
ok i know what that is
