Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-09-2008, 07:14 PM
danford1 danford1 is offline
67 Mustang shock tower mod info needed.
I saw somewhere, and now I can't find where, there was a "kit" or instructions that showed where to cut back the shock towers for more clearance to valve covers and headers.
I know you can lower the upper A arm 1" to gain some handling, this will also help with the amount I can cut off the shock tower. Anyone know where the needed info can be found?
Thanks.
Danford1
Old 03-10-2008, 10:58 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: 67 Mustang shock tower mod info needed.
I haven't seen such a "kit" for a '67. But I have heard of them for the early '70's mavericks. I'm sure they make a similar one for most classics. Have you tried mustangs unlimited?
1969 Cougar
357w & TKO - 475hp
Old 04-05-2008, 10:52 AM
MrPbody MrPbody is offline
AF -Advisor
Why? The FE "big block" was available as a stock engine in '67. What are you trying to do? Usually, where a 390 or 428 "fits", the Lima or "385" (429, 460) engine will fit.
Just curious what you're up to...
Jim
Old 06-11-2008, 02:10 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
The '67-'68 390/428 engine bays and shock towers are different from the 289 powered models. The 390-428 bays are a lot wider and the shock towers are made of heavier stock.
Bob
