Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 03-09-2008, 09:39 AM
mt1958 mt1958 is offline
'01 Beetle : Oil in Engine Coolant
'01 Beetle : Oil in Engine Coolant. Original problem was overheating. Coolant has engine oil in it. Oil cooler?
Old 03-09-2008, 02:14 PM
Kirk in Iowa Kirk in Iowa is offline
Re: '01 Beetle : Oil in Engine Coolant
mt,
Yes, this actually should be considered first. From the shop manual:
"The [oil] cooler is a potential source of leakage between the lubrication system and the cooling system and should be considered whenever such leakage is suspected."
The other source may be a head gasket leaking between the oil and coolant passages. Lets all hope it's the oil cooler...
How hot did the car get, and for how long?
Kirk
Old 03-09-2008, 10:51 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
needs a head gasket and cylinder head machining!
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 03-25-2008, 06:40 PM
The oil cooler was leaking. To test it, I pressurized it with air pressure, and submerged it in water. It made air bubbles.
Old 04-05-2008, 09:21 PM
bratt bratt is offline
does the oil go through the bottom of the radiator? is that the oil cooler you are talking about?
Old 04-06-2008, 06:20 AM
hako hako is offline
I didn't know they had an engine oil cooler - there is one for the auto transmission but none for the engine oil on our car from what I can see. No mention of one in our workshop manual.???
