| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Uhhh?
Ok so when i am in a gear usually happens in 3rd or 5th and i floor it, you can hear the turbo spool quikly but small in any movement on the rpm's.
1996 GSX - Apexi N1 exhaust and downpipe,NGK 10.2 mm plug wires,HKS intake,Blitz turbo timer/boost controller 2003 avalanche
Re: Uhhh?
Could you please edit your post so we can understand what you are saying
Re: Uhhh?
Boost leak. Do a test and fix it.
Re: Uhhh?
what is the best way of doin that??
Thanks man
Re: Uhhh?
Whether or not the turbo is spooled depends mostly on load on the engine. If I getting what you are saying, when you are cruising and you floor it, it build boost very quickly with minimal RPM changes right? Its fine, thats how a turbo is supposed to work. It happens in lower RPM's in higher gears... for example in my 90 TSI AWD with a big 16g I was in 5th on the highway going up a hill. I floor it and had full boost by 2500rpms whereas I get full boost more like 3000 on flat ground in 3rd.
