Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 03-08-2008, 07:24 PM
tgiboney tgiboney is offline
2003 silhouette PK3 key and keyless remote programming
Does anyone have the instruction for programming a 2003 silhouette keyless remote that they can share?
I was also looking for the PK3 key programming instructions, I was thinking about buying a new key on Ebay and the seller says that its easy to program all I need to do is get it cut. Anyone have any experience with this.
Thanks for the help in advance
Old 03-08-2008, 08:13 PM
Re: 2003 silhouette PK3 key and keyless remote programming
Found the info on the keyless remote still looking for info on the PK3 key.
Old 03-09-2008, 01:32 PM
rmellnick rmellnick is offline
I just bought 2 keys from ebay. I need to get them cut. Here are the instructions.
You need the master key!!!!!
1. Insert an existing key into the ignition cylinder
2. Turn the ignition cylinder to ON (Run) and back to OFF
3. Remove the existing key and , within 15 seconds, insert the new key and turn it to ON (Run)
4. The security light will light up for two seconds ti indicate success.
Hope this helps
Russ
Old 03-09-2008, 07:30 PM
Hope this helps
Russ
Mellnick
Thanks for the info and can you let me know how you get along with the keys.
Old 03-13-2008, 08:32 PM
I had the keys cut at my local ACE Hardware cost $2.00. Followed the above instructions and both keys where programmed in 2 minutes or less.
