Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 03-08-2008, 06:45 PM
Wegnerg Wegnerg is offline
95 Riviera windshielder washer pump
Can anyone tell me where to find the windshielder washer pump on my 1995 Buick Riviera (with supercharger)? It is NOT at the bottom of the washer reservoir. It is NOT up by the windshielder washer motor. I took that apart and it only has some gears and a circuit board in it.
wegnerg
Old 03-09-2008, 08:39 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 95 Riviera windshielder washer pump
Yeah the washer pump seems to be a big mystery compared to other GM cars. I believe the '95 model has two reservoirs. The one you saw and another one that has the washer pump motor hidden below but over the area of the top of the tire. Try following the hoses. According to my documentation you have to remove the plastic wheel well trim, then remove 3 bolts, disconnect the electrical connector and hoses.
Timeslip 08/12/06
AF Community Guidelines
Old 03-09-2008, 09:22 PM
Smile Re: 95 Riviera windshielder washer pump
Thank you so much for your response! Will try this as soon as I get more time off from work and maybe some warmer weather.
wegnerg
