Old 03-08-2008, 06:33 PM
Plumpton Plumpton is offline
Send a message via MSN to Plumpton
01 Cavalier Steering wheel noise.
I own a 2001 Cavalier with just over 80,000 Kms on it. Lately I have noticed a whining noise when turning the steering wheel. This noise is happening inside the vehicle only. It happens when I turn both left and right. I cannot hear this noise when I am outside the vehicle. Any ideas what it may be?
Also I notice that when I am braking or slowing down at an intersection the tachometer seems to jump all over the place. It will move from just under 500 rpm to almost 2000. Any ideas what may cause this. I was thinking that it might be water in the gas tank.
Old 03-08-2008, 11:03 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 01 Cavalier Steering wheel noise.
Power steering pump is most likely shot.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-09-2008, 11:03 AM
SLJ2137694 SLJ2137694 is offline
Have you checked the Power Steering Fluid level? If it is low, look for a leak or loose connection. P/S systems can suck air in the return lines and not leak fluid. Is the fluid crystal clear? If it is not clear that may be due to air trapped in the system.
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 03-09-2008, 11:24 AM
The fluid level seems fine. No visible leaks either. Is it true that there is a bearing in the steering wheel assembly itself. Could this be a cause of the noise? It seems weird that it only happens inside the car itself. No noises can be heard outside the car.
Old 03-09-2008, 11:30 AM
muff34 muff34 is offline
Do you suppose that it could just be the ccccold causing this whine you hear . My `00 has abit of a whine also and that is what I attribute it too, I hate the cold and I`m not too crazy about the car either ........lol
Life Is A Highway ,Enjoy The Ride
Old 03-09-2008, 11:33 AM
There is an upper bearing and lower bushing in the steering column. Bearings will fail but it is rather uncommon. Is your fluid clear indicating no air in the system? Can you duplicate the noise with the engine off? If you have a floor jack raise the front end so you can turn the steering wheel back and forth easily. You may still have a noise in the steering system. I have heard noise from the spool valve in the steering gear travel up to the inside of the vehicle but not really be heard as abnormal from under the hood.
Old 03-09-2008, 02:39 PM
Thumbs up Re: 01 Cavalier Steering wheel noise.
Well I think I may have found the issue. I let the car sit for a few hours and I went to check the fluid again. It is actually quite low, about a half inch below the cold mark. I am going to get some more fluid and see if that takes care of the problem with the noise. Thanks for all the suggestions everyone. I love how the people in these forums are so willing to help each other out.
I will try to see if adding fluid will help and if it does then I have to figure out where the leak is.
Thanks again everyone.
