Old 03-08-2008, 02:44 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Just wondering: Transfer case interchange?
I have a chance to get a used transfer case from a 1990 K1500 with 305 or 350 (the tag is missing from the rad shroud and I forgot to look at the VIN) for $60.00. I thought I would rebuild whatever is worn and keep it on the shelf for a spare. My question is, will it fit my 92 K2500 (not HD) with 305 and/or my 88 K3500 with 454? I do have to remove the case myself, so is there anything I should be taking other than the case c/with tail stock? I saw some linkage at the side of the case; is it easier to disconnect at the case, or at the shifter? Where does the wire harness go that's attached to the case? I tried to remove it but there seems to be some sort of clip on top of the case holding the harness in place. We're in the midst of getting a foot of snow, so I didn't want to play around under the truck longer than necessary since I had already removed the skid plate from under the case. It took forever because the owner had undercoated the truck with some kind of very gooey undercoating which made removing the bolts a real chore in this weather. Any help would be appreciated.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 03-10-2008, 04:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Just wondering: Transfer case interchange?
It should fit your 3/4 ton, but you'd have to measure the transmission where it bolts on for the 1 ton.
I would take the linkage as well, unless the T-case is the same number the linkage could be different.
I can't be of any help on the rest, I never had to deal with it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-22-2008, 01:49 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
should be a 231C
good case alot of the 4x4 guys like these for conversions and such
try to get the adapter also
the linkage comes of easier at the shifter leave it on the case
most were combined with 700r4/4L60/E trannies
i have an adapter and case mount from one such combo from a '90 k1500 if you need a pic i have one already uploaded somewhere in my pics albums
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 03-29-2008, 03:11 PM
Got the case; it's a 241C. I couldn't see the tag originally because it was covered in undercoating. The tranny fluid was a nice red colour and the silicone seal where the transfer case bolts to the adapter didn't look too old, so I think this was rebuilt in the recent past. The truck only had about 140k miles on it. I couldn't get the bottom bolts of the adapter loose as they seem to be way into a corner that was too small for my wrench, and I don't have a snap-on 15mm which probably would have had a thinner wall on the box end of the wrench. I also took the shifter and linkage and housing. I removed them first and it actually made the job of unbolting the case easier because I could access the top and top left bolts through the hole in the floor rather than working from underneath around the front drive shaft. I couldn't remove the front drive shaft when removing the case because someone had tightened those four bolts with an impact gun, which is what I used at home to separate the shaft flange from the case. Thanks for all your help.
