Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-08-2008, 12:44 PM
Will308 Will308 is offline
97 low speed rumble
I don't know exactly how to describe the noise. When I lift off the throttle at 30mph, I hear a distinct rumble from the rear of the cabin. Once I give it throttle again the noise disappears?
I'm thinking it's related to the u-joints, since it only happen when power is not applied (coasting)?
Anyone else have a similar problem or know what it is?
Thanks,
Will
Old 03-12-2008, 04:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 97 low speed rumble
If you havn't already, check to see if they are loose. They can make noise and not be loose, but you still need to check them.
Does it make the noise in neutral?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
