Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-08-2008, 12:37 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
E316G wastegate issues
Mods: please move if this thread is better suited elsewhere...
so i noticed today while i was "gettin on it" for a little enjoyment on the way to work, that everything was dandy 1st and 2nd nice, then i hit third and boosted to 22psi and about 4500rpm , i shifted into 4th. well, when i got back on the gas after shifting (no "speed shifting") just a normal grandma shift, the wastegate was still open (i can here it with my external dump) naturally the car built boost REALLY slow in 4th for a good 5-7 seconds, then the wastegate closed and the boost shot up to 22psi and the gate opened again... my question is what can i do to get my wastegate to close faster? anyone else having this isssue? or know of anyone who was dealing with it?
Old 03-08-2008, 02:53 PM
steviek's Avatar
steviek steviek is offline
Re: E316G wastegate issues
never heard of that happening. So it just opens and closes on its own a random times?
If I were you I would just get a new wastegate they are pretty cheap and wicked easy to install.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-08-2008, 10:42 PM
Black99GST's Avatar
no, it opens when i reach my desired boost levels... just i guess it takes a little while to close... i need it to open like it does, then when i shift, close right as the peddle is lifted... but it stays open for about 2-3 seconds after that...when i am already in the next gear and on the gas
EDIT:
It did it again today (3/9) on the way to work (yeah, i work on sundays! SO!) but this time i was boosting in 3ed, and shifted in to 4th, then drove like a grandma at about 10-15 vac... i could still here that the W/G was open for the first 3-5 seconds of driving...
Old 03-10-2008, 02:09 PM
Black99GST's Avatar
no one has any input???
Old 03-10-2008, 02:41 PM
steviek's Avatar
so why not just replace the wastegate? it sounds like its malfunctioning or defective why bother with it?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-11-2008, 12:14 AM
Black99GST's Avatar
because my turbo is brand new, maybe 1500 miles? and i dont want to spend $65... and it end up being a different problem... like my BOV is to "tight" and its surging or something like that, because in theory, since surge is when the compressed air goes backwords through the pipe and puts pressure on the compressure housing, then it would pass the the boost controler as well... of is that thought void?
Old 03-11-2008, 12:27 AM
steviek's Avatar
I don't think its compressor surge but might as well soften your bov and see if it helps... But really what else could it be?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-11-2008, 12:45 AM
Black99GST's Avatar
yeah, i know... i just dont wanna have to buy a new one!
Old 06-01-2008, 10:39 PM
Black99GST's Avatar
well dont mean to bring this back, but i tried a little experiment, and ran the car w/o the boost controller. just fed the positive pressure straight into the wastegate with one line... and what do you know! it works perfect... i guess since you guys know me and all, i feel "OK" asking this question, but since my MBC is obviously F-ed... what MBC can i get that freaking WORKS!?!?!?!
Old 06-01-2008, 10:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
My first thought was the bleed hole on the WG side of the MBC. Make sure it's there and open. Some MBCs put the bleed hole in the NPT to hose barb fitting, so you could have it on the wrong side of the BOV. Others assume you're going to have one installed in the vac line to the WGA. And so on. It sounds to me like that bleed hole is missing or blocked. It's what lets the air out of the WGA when the MBC closes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-02-2008, 07:24 PM
Black99GST's Avatar
awesome keven! i'll take a look closely, if i cant find anything, i'll post some high res pictures!
