Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-08-2008, 11:08 AM
demo_deven's Avatar
demo_deven demo_deven is offline
Send a message via MSN to demo_deven
2002 GMC Duramax No Start
Hey guys, my buddy has a 2002 GMC Sierra 2500 6.6L Diesel with the Allison transmission. He disconnected and removed the shift control module from the side of the transmission, then when he put it back in the truck wont start. You turn the key, all the dash lights come on but when you turn to start it, it seems like the truck is in a gear. We tried it in park and neutral but still the same thing. Does anyone have any suggestions? Because we're lost...
Thanks all, Deven.
"If it runs and moves, DERBY THE DAMN THING!"
- 2000 Ford F-150 4.2L V6 Reg. Cab Long Box 223k. Nothing special, just a beater work truck.
- 1995 Ford F-250 7.3L PSD 2WD 291k. K&N Air Intake, 4" Turbo-Back to 5" Staks through the box. Other then that a good truck for pulling around my toys!
www.SmashCarRacing.com
1997 Pontiac Sunfire
Old 03-11-2008, 07:46 PM
brightbay brightbay is offline
Re: 2002 GMC Duramax No Start
the problem is the PNP switch that your buddy removed was not reinstalled correctly,(This switch denies current to the starter circuit when the transmission is in any gear but park or neutral ) so thefore it will not start. it needs to be adjusted. loosen the bolts securing the switch to the trans.
rotate the switch ever so slightly and have someone in the vehicle attempting to start the truck, keep moving it in small incruments and turning the key until it starts. you have found the proper position, tighten bolts.
