Old 03-07-2008, 03:09 PM
scottsales scottsales is offline
trans problem
1997 ck truck 305 4x4 automatic. truck would shift perfect. yesterday went to drive and if takes off in high gear. it will shift using a snap on scanner and take off in low fine if you command low on the scanner to trans is mechanically fine I think. any help
Old 03-08-2008, 03:41 AM
Jeremy-WI Jeremy-WI is offline
Re: trans problem
anything else happen at this time? Tach, speedo, or prndl all work. It could be a sign that your ignition switch is going bad
Old 03-09-2008, 08:49 AM
Re: trans problem
tach speedo prndl all work have already replaced ignition harness.
