Old 03-07-2008, 03:07 PM
scottsales scottsales is offline
95 blazer fuel problem
blazer has 60 psi pressure approx and will run off of ether. appears not to be firing injectors any ideas
Old 03-08-2008, 09:37 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 blazer fuel problem
Pitch the can of ether/starting fluid before you blow it up.
Only use carb cleaner as a starting aid.
Is it a W or Z code engine and is it PCM or VCM computer ststem?
Does injectors have 12 volts on power side?
Does the computer have injector pulse to injectors?
MT
