Old 03-07-2008, 06:33 AM
andthisismysn andthisismysn is offline
!!!!!!!!!!!no Brake Lights!!!!!!!!!!
here i go again. 95 4 d00r blazer. brake lights dont work and the 3rd brake is also out. i have trun, left and right,parking lights work fine. check bulbs and fuse and they are fine. "please help". the brake lights did work when i first got the truck. my low beams dont work ether.(its not the bulb). i broke the hazard light switch and glued it down,dont know if the brake lights stop working then. i want to now if the 3rd brake light power goes thru the dimmer switch, or stoplamp switch
Old 03-07-2008, 08:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: !!!!!!!!!!!no Brake Lights!!!!!!!!!!
The 3 high mount brake light gets power from brake light switch.
The white brake light switch wire splits two ways
One going to high mount and one going to turn signal switch brake light feed..
Go to brake light switch and check for 12 volt power to it on orange feed wire and 12 volts on white wire out of it to brake lights.
If the hazard switch or dimmer/turnsignal is broke you should repace it.
A broken or stuck hazard switch can knock out left and right brake lights.
But unless it has blowed the fuse or brake light switch the high mount should still be getting 12 volts from brake light switch.
MT
MT
Old 03-07-2008, 11:25 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Just to add to what MT mentioned. I would get the hazzard switch changed.
Here is the how-to on this...
http://www.automotiveforums.com/vbul...d.php?t=595263
Old 03-07-2008, 02:34 PM
i checked the stoplamp switch. orange hot all the time,brown hot when key is on, white and two i think puple or pink no power. i jumped power to the white wire and still no brake lights. i checked out back at the tail lights and i get power to the parking lights when there on.
dose power go from the stop/switch to the hazard switch and then to the lights?
Old 03-07-2008, 02:41 PM
where can you get replacement hazard switch? just called the deal told me no part #. i had to buy the whole blinker assembly
Old 03-07-2008, 06:51 PM
MT-2500's Avatar
AF - Advisor
White wire is the stop light feed from brake light switch.
Should be hot when you step on brakes.
The stop light goes to the turn signal switch and then splits to right and left rear turn/stop lights on turn signal mode.
If no turn signal on it feeds from turn signal switch to both rear stop/signal lights.
You may have to buy the hole switch but some years they had a hazard switch recall/repair deal.
Good Luck
MT
MT
Old 03-07-2008, 11:41 PM
blazes9395's Avatar
Newbie mod
I can gaurentee you, you can buy jsut the switch for the '95.... I did so myself when I had to get mine fixed on my '95.
GM Hazard switch repair Kit part # 15174447.
Old 03-08-2008, 02:06 PM
thanks i found the part .i was trying a chevy dealer,but i found it at the gm dealer
