Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-06-2008, 08:59 PM
E B E B is offline
Stripped out spark plug hole
Our 97 neon 2.0 sohc popped out a spark plug today, when I re-installed it I found that it was stripped. What is the most efficient fix? We are going to be getting rid of it soon, and I do not want to spend alot on it. All help would be appreciated.
Old 03-06-2008, 10:06 PM
CaptSeaweed CaptSeaweed is offline
Re: Stripped out spark plug hole
You might look at : Timesert.com or Fullsert.com I have never used these products, but they look like they will get the job done. Good Luck!
Old 03-07-2008, 07:43 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You can but a re-thread tool pretty cheap and just re-thread it.
2003 Dodge SRT-4
Old 05-23-2008, 05:37 AM
error_505's Avatar
error_505 error_505 is offline
Send a message via Yahoo to error_505
Heli-Coil kit at oriellys for about 30$ 12-14mm
Thanks,
Andy
Jack of all Trades......Master of None
__________________________________________
1998 GMC Jimmy V-6 4.3L
1998 Dodge Neon 2.0L DOHC
2005 Pontiac Gran Prix V-6 3.8L
Old 05-31-2008, 04:32 PM
drifttruck99 drifttruck99 is offline
you would have to remove the head in order to use the heli-coil kit. otherwise you will have shavings from the cutting tool fall on top of your iston and when you start it it will score you cylinder walls and cause more damage.
Old 05-31-2008, 06:20 PM
error_505's Avatar
That is what I done to mine and it has worked fine for a bout a year. Maybe a back tap?
Thanks,
Andy
