Old 03-06-2008, 11:43 AM
palowski palowski is offline
car refuse to start
my lancer just would not start. the battery is good, the transmission is good, spark plugs good, coils good, and the crank angle sensor. everyone i took it too. has no idea y it won't start. i need help asap. thanks in advance
Old 03-06-2008, 07:17 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: car refuse to start
does it have an alarm? you might disconnect it and try, sometimes immobilizer alarms go faulty and cause a nostart. other than that, compression fuel spark and timing. test em all. every part.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 03-07-2008, 08:31 AM
mechband mechband is offline
try to reprogram power control module to clear faulty soft code
Old 03-07-2008, 03:07 PM
j cAT j cAT is offline
i would bring to Mit...car dealer perhaps you will be able to get some trade in value...
Old 03-10-2008, 04:09 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Originally Posted by slideways...
theres no wand that we can wave to make your van start.
I have a rubber mallet that works a lot of the time
Now to the original question... does it have fuel pressure and are the spark plugs actually firing?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-10-2008, 05:20 PM
the car has fuel pressure and everything. it's being worked on now. i bought a crank angle sensor and i am hoping that that would fix the problem. it's turning over and everything but the car just won't start. it's it's not the crank angle sensor the guy said i would have to get the computer checked.
thanks for the comments
Old 03-10-2008, 08:25 PM
well it was the crank angle sensor. the crank angle sensor is basically a distributor. the spark plugs weren't getting any current so the engine wouldn't start. I replaced it and the car is fine
