Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 03-06-2008, 10:04 AM
duramx duramx is offline
Stalling '97 Bravada
1997 Bravada Stalls While Driving w/ no rime or reason
stalls @ various times while driving (slower speeds 20-40 mph)
seems weather does not matter
no ses light it's been to dealer no codes
dealer cleaned throttle body (same Problem)
does any one have any ideas
thanks for your help
Old 03-06-2008, 11:52 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: Stalling '97 Bravada
Fuel filter? Does it run smooth? What RPM does it idle at?
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-08-2008, 10:12 AM
Lightbulb Re: Stalling '97 Bravada
Runs very smooth
idle is normal
I'll change filter and see what happens
thanks for the help
Old 03-09-2008, 09:36 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Does it restart quickly?
Do the dash alarms light up...ABS, seatbelt?
Are the battery connections tight?
Old 03-11-2008, 02:45 PM
glgz glgz is offline
My 97 stalls sometimes too. I found it is a problem in the ignition switch. Next time it stalls see if any of your dummy lights are lite. If they all are out just like it would be when you turn the key off it could be your problem as well. With mine I have found if I turn it off and back the lights come back and it will start. Now when the dummy lights are not coming on then it will just crank all day and not start. I have been dealing with it all winter just trying to get as much time out of it as possible. Dealer told me it is a common failure of the ignition module.
Old 03-11-2008, 06:43 PM
Battery lite & abs lite is on
restarts on first try
if I put in neutral turn key it starts
took off cables cleaned and put them back on
no problem w/starting
thanks
Old 03-11-2008, 06:46 PM
Did you get an estimate on new ignition
thanks
Old 03-12-2008, 09:32 AM
The dealer I talked to thought it would be around $300 put in for a new ignition.
Old 03-12-2008, 12:36 PM
AF - Advisor
Here's a thread on ignition switch replacement but it needs pictures.
http://www.automotiveforums.com/vbul...d.php?t=287636
