Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-06-2008, 09:06 AM
95cavspeed's Avatar
95cavspeed 95cavspeed is offline
Turbo problems <STOCK>91 eagle talon TSI
hi, i have a 91 eagle talon tsi, im gettin 8 psi to the floor in the morning when its cold and it takes about 20mins of driving then it finally shoots to 14 and fast, but it seems faster in the morning when i first start it and its faster at the 8 then at the 14 if this makes since lol, only thing is it runs great has the muffler right at the end of the downpipe, and a k&n filter other then that its stock and does 0 to 60 in 10.30 seconds isnt that bad? its an automatic
what should it do 0 to 60 in cause it says stock it shoul be 6.4 seconds or 7.1 er suntin around that range.
Old 03-06-2008, 10:42 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Turbo problems <STOCK>91 eagle talon TSI
Do a boost leak test, and also do a tune up. Change plugs and wires if they haven't been done recently.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-06-2008, 11:58 AM
steviek's Avatar
steviek steviek is offline
yea a 91 tsi should do 0-60 in about 7 seconds with A/T. Maybe add a bit more cause the motor is 17 years old. But ten is too much.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-06-2008, 10:43 PM
Holset powered 420a
You should be able to hear it somewhat. Make sure to do a boost leak test. If you car is hitting 14psi and feels slow then you may have a boost leak causing the motor to run rich.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-08-2008, 09:25 AM
95cavspeed's Avatar
ok suntin weird happened i was drivin the car , and like 30 mins of driving i shut it off went inside for bout 20mins came back out put it to the floor and it set me back so hard it was pressin on my shoulders madddddddddd fast
, it has never done that before so i dunno what to think now lol, i got autolite platiums and ill gap um at 0.28 and see what happens and maybe do a compression test first and see cause the car runs awesome
HERE IS A PIC OF MY CAR
161,000 MILES ON THAT MOTOR
Old 03-08-2008, 11:27 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
found the problem... platiums dont work for shit on the boosted 4g63... trash them for some NGK BPR7ES, unless you going to run high boost in the near future, i have heard good things about the NGK BR6ES... cap .028...
Old 03-08-2008, 02:26 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Whats up with the 97-99 front bumper cover?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-08-2008, 03:15 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Yeah, never seen that before.
And it almost fits.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 03-08-2008, 03:51 PM
Black99GST's Avatar
And it almost fits.
didnt even notice that... it doesnt look that bad IMO, if you could get it to fit better with some custom work from a body shop, that wouldnt be to bad at all... change those plugs and let us know how that helps...
Old 03-08-2008, 03:57 PM
steviek's Avatar
I actually really like that front bumper on their. Get that side marker fixed and like they said trim it up a bit and it looks really nice with a very interesting little mod!
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-08-2008, 05:56 PM
95cavspeed's Avatar
thanks guys, yeah ill hav it fixed, well i got the autolite platiums installed, and it seems to have a little more kick to it all the time, jus have to figure it out in time i kno its not a motor problem cause it runs awesome and doesnt burn a drop of oil...[
Old 03-09-2008, 03:47 AM
steviek's Avatar
hmm not a very big fan of the blue on the interior it just doesn't seem to match very well and the contrast is too much and its too dispersed. But to each his own
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-09-2008, 10:24 AM
Black99GST's Avatar
looks like a chinese food over cooker (rice)
why did you go with the Platiums? the BY FAR best plug for this motor is between the NGK BPR7ES and the BR7ES... just FYI, if you turn up the boost, those plugs will misfire...
Old 03-09-2008, 10:41 AM
95cavspeed's Avatar
yeah wel my fav is the gauges, the rest has to be all redone anyway cause i got to get the vents and stuff that broke
lol cause my friend had those plugs and im broke to do anything to the car, but i will get the ngks asap, i dont even kno how to turn the boost up ive never messed with a turbo.
Old 03-09-2008, 11:15 AM
bryan_bigd's Avatar
bryan_bigd bryan_bigd is offline
hey man i did not see a after market boost gauge. how are you telling how many pounds of boost. if it is off of the stock gauge then there is no telling how many pounds of boost you are running. long story short i had the same problem. the reason you car spools up boost quick when yoiu first starts it is because the differend weight in oil. then you first start it the oil is cold and there for less pressure on the turbine. oh and i bet your problem with the boost is you probley have a leak in the wastegate port. i had a old turbo in my first gen and when i replaced it i realized that the waste gate had a big ass crack inside it. my turbo was taking forever to spool up and my car was slow as shit. the best way to fix it is to replace the turbo or at least pool it off and see if it has a crack. once i replaced the turbo my car got fast as shit. oh at the auto first gens have a really smalll turbo its not the 14b so if you try and use a 14b or 16g then you will need new coolent lines.
1995 talon tsi 10-26lbs of boost boost controller k&n intake 550cc injectors 255 fuel pump ported head 3 angle valve job hks metal head gasket arp head studs racing manifold evo3 16g ported turbo 34mm wastegate 3in turbo back exhaust no cat act 2600 clutch 7.9 lbs fly aem 9.3 plug wires irradom plugs lowered 2 in camber correction all four wheels 2 3/4in upper intercooler pipe greddy rs BOV racing hard intake pipe apexi NEO fuel manigment system oh and it has the 6bolt motor
