Old 03-06-2008, 08:36 AM
ksuwildcats2004 ksuwildcats2004 is offline
68 c10 transmission question
I have a 68 chevy half ton and it has a manual 4 speed. The shifter is a top mount (no external linkage) and first gear is a granny gear. Not sure the type of transmission as far as make /model but it is stuck between gears and can not get it to shift. Does anyone have any thoughts on how to free it up? Also is there a different tranny I could replace this one with that would bolt right in and not have such a low gearing? Thanks in advance. Roger
Old 03-06-2008, 09:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 68 c10 transmission question
Been doing any speed shifting?
See if you can remove the shift stick and reach in there with a screw driver and get the shifting rods in it back to neuteral.
Also look for wear on shifting stick and shifting rods and forks.
You will need to check a salvage yard interchange on replacing with another trans.
MT
Old 03-20-2008, 07:43 PM
jgrh01 jgrh01 is offline
Try this page http://www.6066gmcguy.org/SM420.htm it may help or contact Jolly he knows about HD trans
Old 03-22-2008, 02:37 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
CH465 unless it is a big block truck then it can be an NP435
there was also a warner and a NP435CRin these trucks years
the CR version was not granny first gear and would bolt right in place of the others
the stick you can remove by pushing out the roll pin at the shifter base where it goes into the top cover
it is stuck in there is all
i have had it happen to me many times with a CH465 in the past
need a flashlight to look down in there and make sure the shift blocks look ok and not broken or anything
these are a very reliable trans and super rarely does anything go bad in them
usually only a synchronizer wears out or maybe a bearing although extremely rare
you could put a side loader 4 speed in it such as a saginaw or muncie but you wil need a different driveshaft, one for a short tail 2wd trans from a 63-72 truck of the same bed length
or hunt the junkyards under cars for one that is the same length
27 spline yoke really common th350 2004r th200C TH250 700r4, 4 speeds, 3 speeds
basiclaly anything except a top loader 4 speed or a th400
the side loder 4 speed will stick onto your top loader bellhousing but the hole will be larger, but if you center it good then it will be ok, i have seen it done a few times i know someone with a 69 c-10 with a muncie 4 speedon the original big iron bellhousing, drives fine
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
