Old 03-06-2008, 06:10 AM
mishalah's Avatar
mishalah mishalah is offline
Question windshield wiper solutions?
I am another T&C owner who has the front wiper problems (only works when using the "wash" button), and have tried the easy fixes (swap relays, swap switch module), but still no normal hi/lo or intermittent operation. They will run several swipes at high speed when the button is pushed, or 1-2 at low speed, so the motor and mechanisms are fine.
I have read dozens of threads about this problem but have not found one where the OP posted the results of his search for a solution. I could assume all of them are still driving with no wipers, but that seems implausible.
SO...what has worked in all of these cases? PLEASE thread starters, if you post a problem, then find a solution...let us know what it is.
Short of replacing the BCM...which I'm not gonna do at those prices for wiper operation I might need 2-3 times a year...I'd like to fnd that elusive "fix".
Old 03-06-2008, 02:54 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: windshield wiper solutions?
While my 96 was under warranty, the dealer changed both the multifunction swutch and the BCM. Two years later they started again. That was 10 years ago. I just pull the fuse during the summer and live with it the test of the year. 90% of the time they only sweep at startup. In your case a BCM is really the only choice if you want to fix it. Don't count on it lasting forever.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
