Slider bolt bushing (guide pin bushing) for caliper
I have installed all new brakes for my 3000GT NA FWD 1995 ATX with no ABS.
Why do I need the rubber guide pin bushing that fits on the end of the guide pin (slider bolt)? Can I remove it and install the slider bolt without it being there?
There is only 1 bushing of this type on the 1 guide pin vs the other "lock pin" which doesn't have a bushing or a groove for one like the "lock pin" does. I figure this was put there for a reason, but it seems too damn tight for the slider action to even work right anyway. HELP ! I have to get this done fast.
I had previously put the wrong slider bolt grease in the bores of the caliper bracket and I'm redoing the slider bolts with proper grease as a result. I'm wondering if the suspension grease I'd used before "swelled" the rubber guide pin bushing while it was in there making it too big for the slider bolt bore thus causing it to lock up pretty well. I can apply FULL force to get the bolt in there and it will not budge at all. This made me think - why do I even need this bushing at all? It seems like the setup would work fine without it.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
