Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 03-06-2008, 02:16 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Painting an FMIC
Hey guys, I have a quick question about painting an FMIC. As some of you probably know, I am going for the "stock appearing" thing in my Talon and because of this (stock appearing = 16g or 18g turbo so it wont need a whole shit ton of cooling power, plus supra SMIC setups are cheap) I wanted to stay SMIC. Well, I already have a FMIC core so fabbing pipes for the FMIC wouldnt be much different than fabbing up pipes for the SMIC. The FMIC core isnt huge and I am pretty sure its just an eBay core, but remember the big 16g on E85 isnt exactly going to need a nuts ton of cooling power. So my question is, if I want to keep it covert will painting the core take a huge cut out of my cooling power? Obviously I wouldnt put it on thick, it would just be a thin coat of probably flat or matte black just so that it wont stick out when you are looking at it, and hopefully people that dont know what they are looking at will just think its the radiator. I do realize that it'll most likely have a negative effect, but I just am unsure as to whether it'll be a big effect or a basically negligible effect. I'm less and less concerned with being super hardcore about the stock appearing, but I'd still like to be unassuming. Also, if this core doesnt hold air (I'm going to test it over spring break) I most likely will just go supra SMIC. Thoughts?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-06-2008, 07:04 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Painting an FMIC
Dont do it, there was a big thread about this on tuners. The paint f*cks with the heat transfer and actually somewhat insulates the core. If you want to change colors then your suppose to anadize it.
Then again you could do it anyways and compare data to see if intake temps are even effected.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-06-2008, 07:47 AM
Thor06's Avatar
Jizzed In My Pants
I saw some "anodizing spray paint" once, does that really work or is it just a anodized look?
If its going to mess with temps then fuck it, I'll just be more obvious what I've got. I do like your idea about testing it though... the thermodynamics part of me wants to put a temp sensor after the filter, after the J pipe, before and after the IC, and in the middle of one of the intake mani runners and then REALLY find out the difference between the stock SMIC, eBay FMIC and name brand FMIC. I dont have the extra money to care, but I wish someone did.
Old 03-06-2008, 07:54 AM
Holset powered 420a
The anodized spray paint just gives you the look. Where does your car measure the temp of the air at? Is it at the maf or on the manifold? You could always test the painting with the stock SMIC and just use a logger to see the intake temps. But this only would work if your sensor is after the IC.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-06-2008, 12:29 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
i wouldnt, especially black, that will get really hot in the sun... just put a dark mesh infront of the IC if you really wanna hide it. i have mesh infront of mine, and its hard to see if you dont know what your looking for...
their may be better pics on my really outdated cardomain... check the sig
Old 03-06-2008, 01:21 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Dude you love showing that pic don't you.
For the temp can't you just use like thermomitors? Like to take your temp? Probably not the best way, but should be able to rig something up like that.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-06-2008, 02:23 PM
Thor06's Avatar
Jizzed In My Pants
And I really like masterbating to it.
I suppose you could Dave, but the IC isnt going to do anything unless there is air moving over it and I sure as hell do not want to have to read the thermometers while someone else is driving.
Old 03-06-2008, 02:33 PM
david-b's Avatar
Dave is THAT guy
You do it to that pic because 1Gs don't get you off.
But I was thinking,... wiring the LCDs to someplace where you can see. All you need is the sensor in the piping, so tear it apart, run the 2 wires to the sensor in the piping, and keep the rest of the unit in the car or where ever. Sure no recording, but keep a video camera on it if you're doing a pull.
75 Monte Carlo
Old 03-06-2008, 03:14 PM
Thor06's Avatar
Jizzed In My Pants
Nah, fuck that... my purple 1g is my #1 but sometimes I have to go with a black 2g, silver evo, or Brian's mom to realize how lucky I am to have the Purple People Eater.
Old 03-06-2008, 03:18 PM
david-b's Avatar
Dave is THAT guy
Damn you do it to Brians mom too? That's like Dejavu
75 Monte Carlo
Old 03-06-2008, 10:51 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I seriously doubt that a little bit of spray paint on the FMIC will make any noticeable difference in cooling efficiency, but thats just my mentality.
BTW: Ive never used any type of thermometer or whatever to check the efficiency of my FMIC, but ive drove the car, then shut it off and grabbed the IC piping before and after the FMIC, and there is a huge difference in temperature.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 03-06-2008, 10:57 PM
Holset powered 420a
I have done that to. The hot side will almost burn your hand sometimes and the cold side would still be chilled.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-07-2008, 08:27 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
I think, and of course Thor I am a little on the weird side of things, that the e85 and sidemount should be able to handle your cooling needs. A friend of mine ran 13 flat with a small 16g and larger sidemount with regular 93 octane. I doubt you couldn't do better.
for the record i will be painting my fmic and using a grill to protect it. What I've researched is a painted ic does not affect efficiency by more that 1-2% which is more than acceptable.
Don't act like you don't love it.
503/2000
Old 03-07-2008, 01:05 PM
Thor06's Avatar
Jizzed In My Pants
Yeah I definately plan on going SMIC if the FMIC is popped.
I think Sleeper is on the righter side on this one. The paint would insulate it to a point, but the vast majority of cooling is going to happen between the front and back of the IC, not much will happen on just the face I dont think so a thin coat of paint shouldnt hinder too much. I guess the other thing I'd have to worry about though, is clogging the fins with the paint. I'll pull the core out in a couple weeks when I am home and pressure test it... if it holds pressure or its just a small JB Weld-able hole I'll use it, otherwise a supra SMIC will be in order. Either way hard pipes will be fabbed up this summer.
Old 03-07-2008, 05:32 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Where I work we build custom made ultrasonic cleaning machines for medical companies but we are building one right now that anodizes titanium. Now I was talking with my project manager and i asked what it takes to do aluminum. He wasn't sure off hand but he said the bath that the parts are immersed in is what you would change with different metals. I was thinking after I read this thread that if our lab has a tank big enough, it wouldn't be too much of a problem to try it out but I wouldn't do my FMIC. Maybe a radiator or something.
Let me know if anyone wants me to pursue this. I don't want it done to anything of mine but would be pretty cool to try.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
