Old 03-05-2008, 02:54 PM
vincynick vincynick is offline
Smile 96 PA - Noise from the passenger side
When I am drive at low speed, I am hearing noise from the passenger side, sounds like I have couple tin cans on string tied behind the car. I am puzzle as to what it is. I know it is not the exhaust. I jacked the car up and did see anything. It only happens at low speed. It does happen when idling, or if I rev the engine. Please help.
Old 03-05-2008, 05:32 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 96 PA - Noise from the passenger side
More than likely, what you are hearing is the catalytic converter. When this thing breaks loose from the inside, fragments of the catalysts swirl around in the housing and sound like “tin cans dragging behind the car". Take it to a muffler shop where they can put it in a rack for inspection. (You can not see this from the outside). Replacement cats run around 125-175 bucks installed, depending on where you take it. MagnaFlow cats are a good replacement.
Old 03-06-2008, 11:40 AM
Thanks for your reply. Do you know where I can purchase one only and help with the specific unit that I need would be appreciated.
Old 03-06-2008, 01:35 PM
HotZ28's Avatar
AF Moderator Elite
MagnaFlow Exhaust
1996 BUICK PARK AVENUE
Engine: V6 3.8 Liter
Part Number: 94806
Catalytic Converter: 94800 Series Round; OBDII Compliant; Universal; 2.5" Id; Without O2 Boss; Front
Available @ Advanced, Pep Boys, O’Rielly
