Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-05-2008, 10:28 AM
rjer3's Avatar
rjer3 rjer3 is offline
Smile Tire Size
Got an 01 Dodge Ram 1500 SLT Quad Cab short bed (standard), I was wondering whats that max size tire I could put on this truck without doing any modification, it currently has 245/75r16 like to go bigger and wider with no rubbing while turning or bouncing. It looks like it has alot more room.
Old 03-05-2008, 03:28 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: Tire Size
If you have a 4wd the max tire size is
Stock height: 265/75R16 (this is the stock tire size).
Probably OK: 285/75R16, 235/85R16, 255/85R16, 32/11.50-16.5
With a 2-3" lift: 33/12.5-16.5, 315/75R16
With a 4" Lift: 35/12.5-16.5
I am currently running P285/75R16 and I rub at full lock on my control arms.
If you have 2wd then If you go with anything larger than a 31 x 9.5 x 16, you will have "rubbing" on your front tires when in tight turns.
Found info at http://dodgeram.info/tech/mods/tires/index.html
Old 03-06-2008, 08:06 AM
rjer3's Avatar
Re: Tire Size
so I can run P305/70R16 with no problems include no rub
Old 03-06-2008, 03:47 PM
Re: Tire Size
with that size tire you would need a 2" or 3" coil spacer to clear with no rubbing due to the width of the cross section.
Old 03-25-2008, 08:58 PM
rjer3's Avatar
Smile Re: Tire Size
okay than how about P265/75R16
Old 03-26-2008, 03:24 PM
Re: Tire Size
yes you can clear that tire size no problem. It was a factory optional tire size for an upgrade.
Old 03-27-2008, 08:48 AM
rjer3's Avatar
Re: Tire Size
so 275/75R16 will more than likely rub also but not much being as the 285/75R16 wil rub and the 265/75R16 doesn't right.
Old 03-27-2008, 04:54 PM
Re: Tire Size
I personally don't hear too much about 275/75R16 tire size being available. The most common sizes are the 265/75R16 and 285/75R16. But since my 285s don't rub too much I would say the 275s will fit no rub. They just may be more expensive then the 265s and 285s since it is not as a common size.
Old 03-30-2008, 01:40 PM
rjer3's Avatar
Re: Tire Size
okay thanks for your input.
Old 04-27-2008, 06:36 PM
whiteboy6949 whiteboy6949 is offline
Re: Tire Size
i have a 2000 1/2 ton 2 wd and i have 285/75 r16 i have no modifications and there is no rubing at all
