Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-05-2008, 10:09 AM
DRAFT DRAFT is offline
Mpg
I Got A 2000 Ram W/360 I Need Better Mpg And H.p/tq I Keep Hearing About Cold Air Intake/superchips/k And N Air Filters/spacers I Really Need 2 Know What Is Going To Work Best
Old 03-09-2008, 12:58 AM
rockwood84 rockwood84 is offline
Re: Mpg
if your getting 11 hmpg on the 360 then thats about all you gonna get. the bore has you pretty well stuck around 11mpg highway.
Old 03-13-2008, 08:15 AM
Re: Mpg
So If I Wanted To Put headers/k@n Cold Air Intake/cut The Cat Off/get Thottole Boby Spacer/superchip Programmer That Wont Up My Mpg By 5-8 X
Old 03-13-2008, 01:31 PM
Re: Mpg
a 5.9 [360] was made to pull loads [if it only had a trans that would stand up to it]not fuel efficiency . you might put all that stuff on and only up your mpg to 12 mpg.a 5.9 has a big bore and there's not a whole lot you can do to up the mpg. the 318 is alot better on gas because it will pull a load but not near as good as the 360.
Old 03-13-2008, 10:58 PM
Re: Mpg
Yeah I Hear You But Im Onlt Gettin 9 Miles To The Gall!if I Can Get At Least 12-14 City I Will Be Happy Thats Y I Was Asking About Getting All Of That Stuff. Ps You Wouldnt Happen To Know How Much Hp/touqge Im Gettting Would You?
Old 03-14-2008, 01:20 PM
Re: Mpg
not off hand.might do a search on here as i'm sure it on here somewhere. you might change the gear ratio in the front and rear and get 12 to 14 city.9 mpg city is about right. higher gear ratio would give you more highway mpg not sure about city.
Old 03-14-2008, 01:31 PM
Re: Mpg
not off hand . don't see it getting 12 to 14 city. you might put all of what you are talking about and get 12 to 14 highway mpg. most of the 5.9 s around here only get 11 highway mpg no load. 8 to 9 pulling load.
Old 03-17-2008, 05:38 AM
HV2JEEP HV2JEEP is offline
Re: Mpg
The best way to improve gas mileage on a dodge truck is to get a commuter car. And when you don’t have to haul something then take the car. You can cut your gas bill by 2/3rds. your truck gets 9-10 mpg if you get a lets say a vw or Honda that gets 30+mpg then think of the savings. I only say this because that’s what I just did. Though I am still adding all the stuff you are suggesting but for power not fuel efficiency.
2000 Jeep Grand Cherokee limited 4.7 V8
2001 Dodge Ram 2500 8.0 v10
K&N, true duel exhaust, 9’ Boss plow
1997 jeep wrangler TJ sport 4.0 I6
4” Super Lift, Waren bumpers, 33” BFG MT
1996 Volkswagen Passat GLX V6 (just got it)
Nothing yet, but mods coming soon.
Old 03-18-2008, 07:57 PM
Upstate Upstate is offline
Re: Mpg
I took my 98,1500, 5.2 with 98K from 11 mpg to 14 mpg last summer by first burning a couple tanks of mid-range fuel with most expensive commercially available FI cleaner I could find before going back to regular. I think the biggest difference was adding tire pressure from 35 to 45 psi. Tires are rated for 50 psi but didn't want to go there. The door sticker pressure is for vehicle dynamic stability. Must drive more carefully and slower, but thats works for you too. Internals of cat collapsed in late fall and O2 sensors acted up after that repair. I don't think it was related. 100K and the truck is still a learning experience. Speaking of fuel, most blends of ethanol will produce slightly lower mileage than straight gasoline.
Old 03-19-2008, 07:40 AM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
Re: Mpg
If I could find even one gas station with straight gasoline anymore I'd be a sworn customer.
It's not idiot proof, it's idiot resistant. You just haven't found a big enough idiot yet.
Read the rules, and play nice with people.
