Old 03-04-2008, 10:23 PM
701-3000GT's Avatar
701-3000GT 701-3000GT is offline
SOHC rear-mount turbo
Hey guys, i have a 1997 sohc mtx 3000gt and i have been looking at STS rear mount turbo system. they seem like they could be worth it and i know theres at least one sohc with one out there already. however im pretty lost as to what i would have to do other than the full rear mount system, such as the ECU and injectors and fuel rails.and i also know of the very limited aftermarket for the sohc, so that also doesnt help much. If i do follow through with it , i also dont plan on boosting much more than 5 or 6psi. so if you guys have any input or information about it id really appreciate it. thanks
Old 03-04-2008, 10:48 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Re: SOHC rear-mount turbo
Sid!
Everyone the OP is my good friend whom I have mentioned before. He is by no means a noob. We got curious after meeting and hanging out with a guy who has a rear turbo ls1 trans am, and we started wondering about a rear mount for his sohc...anyone with info it would be greatly appreciated if you shared!
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 03-04-2008, 11:05 PM
AutostradaVR4 AutostradaVR4 is offline
im a little confused. it's a single turbo, correct? does it only feed the rear bank?
EDIT: alright, just did a quick search, and i assume your talking about this?
http://www.ststurbo.com
thats interesting. ive never heard of anyhting like that. sure is alot of plumbing though. Would it be more cost effective to buy a DOHC instead?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-04-2008, 11:22 PM
701-3000GT's Avatar
yep its a single turbo that actually requires no FMIC or any type of intercooler for that matter, so that actually ends up using about the same amount of piping as a traditional FMIC just stretched out a little more. It also claims 97% effeciency if you do choose to install an intercooler
but the universal kit all together is a little less than $3000 and will get me around 250-270 fwhp on 5psi from what i understand.
i hadnt acutally heard of them untill this weekend also, but i found out about them by actually hearing them, they are insanly loud, in a good way of course.
im just wondering what internals i would have to swap out to support the boost such as ECU and injectors like i said before, i am curious about pistons and rods also but i really doubt i would need those unless im boosting somewhat high psi
also like taylor said above, we talked to a guy with an STS system on his WS6 and he said it took a total of 6 hours to install from start to finish, so im thinking that would be a lot less of a headache than a DOHC swap from what ive heard
Old 03-04-2008, 11:41 PM
+100 hp from 5psi doesnt seem right...I would email the company and see if they can give you some estimates. Those number's seem more suitable for a DOHC running 5psi...
anyways, i would say you would be good with stock TT/VR-4 parts (injectors, rails, etc), but im not even sure if they're compatible.
Formerly BlinkRA182
Old 03-05-2008, 12:16 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
I am so glad that i have read this! STS are piles of shit!! and i mean that.. I personaly no the owner.. he is a cool guy.. but his products suck balls!!! the whole idea is retarded!! and his dino number are total BS!! STS blows up more shit then and company i know!! I am not kidding when i say stay away!!
My friends Z06 had them on it for about 6 months.. and Fucked his car over.. at 5 psi.. its just a plan dumb idea.. sounds bad ass though.. i will give them that.. anyways.. steer clear..
Jason
Old 03-05-2008, 07:27 AM
701-3000GT's Avatar
ahhhh
hahaha
alright, thanks.
Old 03-05-2008, 02:58 PM
701-3000GT's Avatar
would there be any other way to boost my sohc without too much major fab work?
Old 03-05-2008, 03:07 PM
Hey jason, wouldnt it be allright to not boost as much...say 5 psi or so? Even if it may not produce the dyno numbers, it would still add a fair amount of power
Old 03-05-2008, 04:51 PM
have you looked into a conventional turbo or tt setup? I would think it may even be cheaper.
Formerly BlinkRA182
Old 03-05-2008, 05:00 PM
701-3000GT's Avatar
i have looked into the conventional a little bit
seems id have to custom fab almost everything but the turbo and piping right?
but im thinking the tt swap wouldnt be really worth it
maybe ill just take the easy way out
buy an older VR4
Old 03-05-2008, 05:42 PM
jason_bet's Avatar
Thats a good idea!
Jason
Old 03-18-2008, 06:57 PM
973000GTPR 973000GTPR is offline
I would suggest a rippmods supercharger, the kit comes with everything you need bigger injectors and new fuel pump. Only other upgrade you need is headers. Comes all tuned and ready to go just takes a lil bit longer to put on.
http://www.octane.lv/index.php?main_...2e666052f1ac3b
Old 03-18-2008, 10:08 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
RIPP mods doesn't even off a SDS anymore. Fact is you can get more power, cheaper and easier with a TT swap.
Old 03-19-2008, 06:32 PM
but you cant put twin turbos on a sohc besides you would blow your manifolds right to shit.
