Old 03-04-2008, 10:36 PM
stevefly stevefly is offline
Question Turn Signal Flasher - Trying to Locate
I am having trouble with my turn signals and have ruled out the fuse and the bulbs. The next thing I want to try is the Flasher for the Turn Signals but I can't locate it. It is not in the fuse box on the side of the dash and I have looked under the driver side dash but have only located some black boxes that I don't know if these might be what I am looking for. Can anyone direct me where to specifically look and what it should look like?
Old 03-05-2008, 07:08 AM
N8SBlaze N8SBlaze is offline
Re: Turn Signal Flasher - Trying to Locate
I have a 97 Blazer and my turn signal and hazard flashers are located under the heater A/C controls behind the knee cover. If your hazards work, try swapping that flasher with the turn signal flasher to see if that is the real problem. If that does not fix it, then do a search on the forum for "mutli function switch". This is the switch that operates the turn signals, cruise contol, and wipers. It has been a problem on these vehicles.
Old 03-05-2008, 11:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Always give year make and model.
Like what is the first thing they ask for when you go to buy parts?
MT
MT
