Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 03-04-2008, 04:54 PM
armagh armagh is offline
center roller on sliding door
Iyt lookinke I may have to replace the center roller on one of the sliding doors it is making a loud noise whe opening and it sounds like it is coming from that area. how do I do this.
Thanks
Old 03-04-2008, 11:33 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: center roller on sliding door
First make sure there is enough lubricant in the sliding track for the roller to glide on. Is the roller damaged? Perhaps the noise you here is the roller on bare metal without any grease to keep the noise level down?
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-06-2008, 05:47 PM
rockwood84 rockwood84 is offline
mine had a small rock stuck under it if nothing is caught under it lube it up
Old 03-10-2008, 10:21 PM
How do I lube it what type of grease.
Thank you
Old 03-10-2008, 10:34 PM
I applied lubricant,(lithium grease) to the upper and lower tracks that the door slides on. I used a plastic glove to apply the grease to make sure I got it in all the areas. I then ran the door over the newly greased tracks a few times to make sure the grease was distributed enough. As the sliders for the door passes over the grease, they pick some of it up and get lubricated in that fashion.
