Go Back   Automotive Forums Car Chat > Suzuki > Samurai
Old 03-04-2008, 01:41 PM
EddieT EddieT is offline
Smile 88 Sami brake pressure metering valve
I just purchased my first Samurai and have a few problems that I could sure use some help with. It has about a 3inch lift so it is not standard factory.
Just had the align and tire balance done and found some bearing problems along with some other problems that will have to be addressed later.
The area I need to fix now is the brake pressure metering valve (mounted near back on frame) is leaking, is there a kit to repair it or do you have to purchase a new one. If it has to be purchased where can I get the best price?
I hold on just one problem at a time.
Thanks for any help
Nemo
Update:
I purchased a new one and replaced it. I found out t is repairable after I pulled it apart. There is a rubber gasket in it that will allow it to leak.
