Old 03-04-2008, 11:35 AM
ocaiomh ocaiomh is offline
Thumbs down hard start - tach
I feel like I'm rebuilding this sucker from the ground up. I had sporadic hard starts and a die-out at low speed. It was coding crankshaft position sensor but the mechanic assured me that it was history only and the problem was the Throttle position sensor. I had that replaced, but the problem didn't go away. Now what she's doing is starting hard after being driven 10+ miles - never cold. The tach is also periodically cutting out. I think I may be looking at a combination of ignition switch and crankshaft position sensor. She's a 97 3800SE. Can anyone tell me how to replace the sensor?
Old 03-04-2008, 01:53 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: hard start - tach
Welcome to AF.
Based on your symptoms crank position sensor. We have a CKPS replacement procedure applicable to the SII 3800 Vin "1" and "K" engines at our Tips & Maintenance forum. See link below.
http://www.automotiveforums.com/vbul...d.php?t=652664
Timeslip 08/12/06
AF Community Guidelines
Old 03-04-2008, 03:35 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
You need a new mechanic. As bnaylor stated, you have every symptom of a bad CKPS, including the trouble code for it. Why would your mechanic suggest a TPS?!?!?!?!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-05-2008, 08:22 AM
Thanks, guys, I appreciate your help.
