Old 03-03-2008, 06:53 PM
grave digger grave digger is offline
"wtf"
98 GAGT 2.4 automatic Car was running great then today was pulling into a parking spot at the store and the rpm's shot up to 3,000 and it took all of my weight on the brake to hold the car still. had to put it in neutral turn engine off to stop. no engine lights. what do I do now?
Old 03-04-2008, 03:39 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: "wtf"
Check the throttle body valve and cable for binding, could also be the IAC
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-05-2008, 06:21 PM
Re: "wtf"
I do appreciate all of the advice I receive here. I am also egually grateful that so many take the time to show interests in my automotive problems. However the idle problems were caused by a collapsed emissions hose that ran to the oil seperator from the intake. The hose was resting on a tab on the back of the throttle body, when the hose heated up this tab pushed in on the hose causing it to collapse.
