Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-03-2008, 10:09 AM
hyundaiaccent15 hyundaiaccent15 is offline
Question Engine Tick
I noticed a lifter tick a while ago i no for a fact it is because it only happens sometimes and goes away and all my buddys who own dsm's say its a lifter. But as time went buy it got louder and doesnt clear up does that still sound like its a lifter?? Do they ever contiunously make noise? Im trying seafoam tonight and puttin 10w30 oil in it hopefully that helps clear it up seafoam is said to do wonders.
Old 03-03-2008, 10:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Engine Tick
Lifter tick (I believe) doesn't go away. It will continue to make noise until they get replaced. I'm not sure if seafoam will work, but always worth a try. Someone correct if I'm wrong.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-03-2008, 10:38 AM
Re: Engine Tick
it actually can go away lifter tick occurs due to oil port through out center of lifter is clogged and it vibrates around makign a ticking nise b.c no oil can pass throw it. Machanics say it will go away im goign to try seafoam. To change the lifter do you have to pull the head?If needed i will but i hate setting timing.
Old 03-06-2008, 09:57 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Engine Tick
You can change the lifters out with a flathead screwdriver in an hour with the head on and cams in. I did it with a 4G63 head but I have no idea what head you are talking about since you didn't say.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-06-2008, 10:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine Tick
Alot of the 4g63 motors have lifter tick. There isin't anything you can do about it. Some people change oils and it will go away or upgrade to the 3gen lifters.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-07-2008, 02:14 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Engine Tick
Sorry dude, but are you sure you havent got a rod knocking. In my experience lifter tick sort of comes and goes and doesnt really get much louder... rod knock starts off sounding like liftertick and two blocks later it sounds like theres a midget in there with a pickaxe.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-07-2008, 08:31 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: Engine Tick
This is true although I wouldn't use seafoam cause its tough on seals but use Auto-rx. It safely cleans without solvents.
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-07-2008, 09:07 AM
Holset powered 420a
Re: Engine Tick
If he had a rod knocking he would damn sure know it after a few miles. It would seem as though he has driven a lot and it only gradually gets louder.
98 Eclipse GS Turbo
2001 BMW 325i - DD
