Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 03-02-2008, 11:46 AM
Lowerdjoker Lowerdjoker is offline
Angry engine popping under acceleration
1986 chevy 305 some mods done to engine like 202 heads slight cam. engine starts and runs fine at iddle. rev motor up starts popping threw the carb? replaced cap button plugs wires checked timing & vacum all good. next pulled one spark plug wire at a time to see if it would stop no change. motor has about 3,000 miles since rebuild. some ideas please? thanx
Old 03-02-2008, 01:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: engine popping under acceleration
202s on a 305? How? The bore is too small for those valves!
Anyhow, there are numerous causes of this behavior, including vacuum leaks, a lean mixture, incorrect ignition or valve timing, and/or maladjusted valves, worn lifters/cam lobes or weak valve springs.
If it has a flat tappet cam in it, did you follow the proper cam break-in procedure? If not, you probably already need a new cam and lifter set. What type of engine oil are you running?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-02-2008, 02:45 PM
Blue Bowtie's Avatar
Registered Offender
Silicon listed lots of very good possibilities. I'll try to narrow it down even more - Check the cam timing. Use a degree wheel. Been there...
Old 03-11-2008, 03:40 PM
luxeryvic luxeryvic is offline
could be knocking from to heavy of a fuel/air mixture
try tuning your carb
Old 03-12-2008, 12:54 AM
silicon212's Avatar
Confoundingly Lucid
A rich mixture will never cause a knock. A lean mixture, however, can.
My bet is on cam timing or a bad camshaft.
Old 03-12-2008, 11:16 AM
oh ok thanks
Old 03-16-2008, 03:55 AM
HeavyChevy82's Avatar
HeavyChevy82 HeavyChevy82 is offline
I had the same issue with my 80 Camaro. My accelerator pump was bad, after I rebuilt the carb it ran like a dream.
