Old 03-02-2008, 11:22 AM
girlfriday237 girlfriday237 is offline
I need alittle help 1998 c3500 idler
Okay here's what happen I was driving down the road and I actually thought I was running out of gas when the truck started to somewhat buck alittle I was wrong .... I pulled over and poped the hood to find the idler was braking . I towed it home went up and got a new one put it on . now the truck won't start . Does anyone have any suggestions to what could cause that to happen ? I really don't want to take this to the dealership .
Thanks in advance for any help !!!!!!!
Pam
Old 03-02-2008, 12:08 PM
Blue Bowtie's Avatar
Registered Offender
Re: I need alittle help 1998 c3500 idler
What engine is installed in the truck?
Does the engine crank but not fire, or does it not even crank?
Is there any noticeable popping in the intake or exhaust?
Do you hear the fuel pump run for two seconds when the ignition is first turned on (turn it to RUN, not START) ?
Can you test for fuel pressure?
Old 03-02-2008, 12:24 PM
Hi here are my answers how u can give me some advice thanks again , Pam
What engine is installed in the truck? 454
Does the engine crank but not fire, or does it not even crank? cranks but no fire
Is there any noticeable popping in the intake or exhaust? no to both
Do you hear the fuel pump run for two seconds when the ignition is first turned on (turn it to RUN, not START) ? yes I just replaced the fuel pump and filter about 2 months ago
Can you test for fuel pressure? not sure how to do this
Old 03-02-2008, 12:25 PM
sorry typed a little tooo fast I meant to say I hope you can give me some advice
Old 03-03-2008, 05:17 PM
J-Ri's Avatar
J-Ri J-Ri is offline
There is a test port on the fuel line right before the throttle body. Just screw the tester (available at auto parts store, often as a loaner or rental) on the test port and cycle the key a couple times. I believe the pressure should be 60-67 PSI on these, but I'm not 100% sure on that. Even a few pounds low on a vortec can cause a no-start. If you have fuel pressure, check for spark.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-05-2008, 07:59 AM
Jeremy-WI Jeremy-WI is offline
I think the pressure spec on the 454 is 56-62psi. Have you checked for spark at the plugs?
Old 03-09-2008, 04:55 PM
Hi checked the pressure is right where it needs to be now , thanks you that was helpful so that may have been part of the problem but There seems to be no spark at the plug .
Thanks everyone for all your help so far I really APPRECIATE IT , and I will keep posting as I elimate stuff .
what does anyone think about maybe a timing issue?
Old 03-09-2008, 07:36 PM
tempfixit tempfixit is offline
Do you have spark from coil to distributor?
Old 03-10-2008, 05:41 PM
J-Ri's Avatar
If no, there a chance the belt was flopping around and damaged the crank sensor and/or wiring.
Old 01-25-2009, 04:16 PM
usa157 usa157 is offline
Check for bad fuse on ignition . My 1988 did that to me .
