Old 03-02-2008, 09:39 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Clearing DTC. drive cycles?
I've got a 98 Pontiac that needs to pass inspection asap. I can manually clear the DTC with my auto tap but then I'll need to drive it until it does all its checks. Any other way to clear the codes. How many drives cycles does it take?
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 03-02-2008, 10:04 AM
j cAT j cAT is offline
Re: Clearing DTC. drive cycles?
whenever you clear dtc codes it does not matter how you still will need to run vehicle on the highway and on some back roads for about 20-30min at normal operating temp. to relearn .......
Old 03-02-2008, 10:42 AM
Headnsouth's Avatar
I understand that part but how long does it take the vehicle to clear the codes by themselves?
03 GMC Sierra 100k
Old 03-02-2008, 06:05 PM
UncleBob UncleBob is offline
AF -Advisor
that can vary widely depending on the code and the system and your driving habits.
I'd just clear the codes. Drive cycles are much faster
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-05-2008, 06:48 PM
Dz Nutz Dz Nutz is offline
What kinda codes you getting? Just clearing them will not reset anything. Unless they are intermittent codes, then you may get by for a bit before they reset.
