| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Is the emergency brake a good place to start learning?
I haven't worked on cars before, but I want to learn.
The emergency brake on the 99 dodge grand caravan doesn't work, so I thought I might start with that. I've been doing a lot of reading, at various sites, and was wondering if the emergency brake may be too complicated for a beginner. I'm mechanically inclined, but I do not come from a car oriented family at all, so I don't know anyone who could supervise me. Is it a bad idea? or should I go for it? Will I look stupid bringing it into a mechanic afterwards if I mess up? or is that fairly common? Last edited by zudo; 03-02-2008 at 10:45 AM. Reason: clarification |
Re: Is the emergency brake a good place to start learning?
Re: How hard is it to change brake shoes?
Next year I'm doing a dual credit program with my high school and communtiy college for a few automotive classes on engines... I checked, and they have nothing over the summer so... Is there a part of a car that I could get started on that's not too hard to mess up?
I would think in general, most alternators are fairly simple. Or prehaps take off a tire, get a book and see how much you can identify without taking anything else apart. Oil changes are rather simple as well. Or rotate your tires. Simple things like that were what I started on.
Most libraries have a car section. You can also try the DIY section of autozone.com. Most parts stores will carry Haynes manuals (which aren't the best, but they're better than nothing.)
Just make sure you read everything you can before starting, and don't take anything apart if you don't think it will go back together. |
I've been reading from autozone, advancedautoparts, and eautorepair, I've got a haynes book in the mail, I'll check out the library later...
You know what? Screw it.
I'm competent, we have tools galore, I can call a mechanic if I mess something up, but I'm mechanically inclined and I think I can fix my e-brake. I found out that I do have a few friends who know a little bit about cars too, so I'll call them up at the time. I'm gonna have to by some things, but oh well right, I'll use them later on. Spring break is coming up, so I won't have to drive to school, I'll read/research until then, and look under the car just to see if I can best guess it (I'm good at that, I fixed random things when I was younger). Patience is a good thing, but patience can wait, I hope this isn't just the caffeine talking (it's 1 am) but Hu-Ha! |
brake shoes aren't hard. but they're a massive pain in the ass sometimes.
Seatbelts Saved My Life
Replacing brake shoes goes one of 3 ways:
Its real easy. So easy, you think you got something wrong. Its a real pain in the ass. You lose a spring, or don't they adjust right, or there is a huge lip on the drum and it won't come off etc etc, It works. But you have parts left over, and your sure you put a spring on backwards. But, the brakes work, the car stops. So its ok, or thats what you keep telling yourself.
With the correct tools it shouldn't be to hard. Go to this thread and find your vehicle.
http://www.automotiveforums.com/vbul...d.php?t=890909
03 GMC Sierra 100k 05 Infiniti G35 150K 10 Mazda 3 Hatchback 110K 16 Infiniti Q50 Red Sport 34K |
you have an adjuster on the mechanism. this accomodates for wear of the shoes or drum.
drums last a long time, the biggest problem is the lip that forms on them.
The adjuster is for shoe wear ..... |
I subscribed to eautorepair a few days ago,for the van (it's powered by mtichell). J cat, your talking about having the drum to spec thickness, right? and straight six, your talking about the need to have it machined, right?
Also, I hear a groan coming from the back right when I hit the brake sometimes, might that be the shoe? or is it possible it's from the drum brake itself? Someone told me that the typical problem for emergency brakes is the cable, how do you insepct that? or should i be fairly obvious when I remove the drum if it's the cable or not? |
