Old 03-01-2008, 09:42 PM
drdd's Avatar
drdd drdd is offline
problems with mirrors leaching battery power?
anybody had problems with aftermarket rearview side mirrors leaching power from the battery causing battery drain?
1997 GMC Jimmy:
... automatic carwash took out my driver's side rearview mirror
... replaced with Advance Auto brand
... it was an easy intall ... I just removed inner door panel, bolted it in and connected one electrical connector. It is a power rearview mirror - but not heated or lighted ...
I had trouble starting two times. Both times I got clicks from the starter. I charged the battery and it started up fine. However, if I left any accessories on after turning the vehicle off, within 3 minutes, the battery would be drained enough for it to not start -- then, click-click-click
I'm gonna try charging the battery for 5-6 hours tonite. It has an auto shutoff so I'm not worried about overcharging.
The battery is only about 3 yrs old from Autozone -- it ought to last longer than that right ???
CCA is 650 I think ...
Old 03-01-2008, 11:12 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: problems with mirrors leaching battery power?
unplug the mirrors and see if the your problem goes away.
Old 03-02-2008, 12:09 AM
Spectria, L1 MT's Avatar
Spectria, L1 MT Spectria, L1 MT is offline
Send a message via AIM to Spectria, L1 MT
If Autozone batteries are Excide, then 3 years is a loooong time. They are junk, but cheap enough to get folks through.
