| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Car cuts out
I have a 1991 Camaro V6 3.1 MFI. It will cut out when ideling if ran long enough or if you rev it, it will cut out. I have replace the spark plugs and wires, cap and rotor. also fuel filter and the fuel pump. and nothing seems to be helping. I am starting to lean towards a sensor now. But I am not sure which, or if there is anything else it could be. Does anyone have any ideas?
Re: Cut Out
I would take a look at the TPS (throttle position sensor)
Re: Cut Out
I dont think that is it because for one there sould be a code for it when the circuit is not working and second the ECM sets a default value for it when it does go so you can still drive it eventough it will run like shit
Re: Cut Out
crank sensor?
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
Re: Cut Out
there isnt one on it
Re: Cut Out
Re: Car cuts out
Well I tested it anyway and everything was ok with it except for the ohm at high throtal it dropes a bit but that cant be the problem because I am having the problem at idealing.
Re: Car cuts out
Do anyone have any ideas?
Re: Car cuts out
IF i am thnking correctly, testing resistance is reverse of voltage, and the dead spot is at idle.
Re: Car cuts out
What are you talking about it is not at idel it is a full throatle I know this because my hand was holding it open
Re: Car cuts out
Yes, WOT would be max voltage, which in turn should be minimal resistance (ohms)
Just trying to help you out. Last edited by wrightz28; 03-10-2008 at 03:13 PM. |
Re: Car cuts out
sorry if I came off like an ass didnt mean it like that
Re: Car cuts out
No problem
So when it 'cuts out', does it fire right back up with no problem? No other running / driveability issues? |
Re: Car cuts out
yeah it starts right back up
Re: Car cuts out
I'm telling ya, it sounds as if the ECM is losing sight of where the throttle or air/fuel ratio is at for a split second and sending it into a fit. Since you've confirmed you do have a dead spot in the TPS, there's a problem already, they're relatively cheap, I'd replace it, and reset the ECM and see how it does. Believe me, I am definately not one to 'shotgun ' parts, i'm a get it done right the first time. There are a few other things possible to cause this, but you know it has a problem in it, so at the very least it will be eliminated from the picture. Yes, i usnderstand your logic that performance wise, where the spot is located should logicly cause a loss of reference at a open throttle situation, but the overall resistance of the circuit could be lessened, thus creating a 'out of range reference voltage in the TPS circuit'. And as stated before, on GM OBDI systems, it's not too uncommon it will not throw a hard code to set off the CEL. |
