Old 02-25-2003, 04:49 PM
Modelcargarage's Avatar
Modelcargarage Modelcargarage is offline
Send a message via AIM to Modelcargarage
Custom rollcages
i wanted to know how you build custom rollcages i have tried with the plastic trees from the models but i have failed any ideas?
Old 02-25-2003, 04:54 PM
SirWelshy's Avatar
SirWelshy SirWelshy is offline
broze rods n tubing or metal rods inside plastic tubing bent to shape, should be able to get either at local hobby shop
todo -->> Dan Finks speedwagon, taurus, lotus 107, `60 chevy hardtop, austin martin db6, austin healey 100-six, datsun 610? and bmw
http://www.pearce.50megs.com/model.htm
Old 02-25-2003, 04:57 PM
sweet
thanks man ill try that
Old 02-25-2003, 04:59 PM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
a cheep and effective way to do this is by using the trees your parts come on...cut and shape and reglue as desired...
Old 02-25-2003, 05:01 PM
hahahaha
thanks k dog ill try that
Old 02-25-2003, 05:11 PM
espin espin is offline
You can buy styrene by the rod. That is what I use to make them. Use a lighter to heat it up to bend it. Tree pieces tend tt have hollow pieces that do not work good.
Craig
Click here for more pics!
Old 02-25-2003, 05:14 PM
thanks
thanks for the tip
Old 02-27-2003, 08:53 AM
Bookshelf's Avatar
Bookshelf Bookshelf is offline
My friend and I made a rollcage our of that scap plastic U get. U heat it up and then bent. It turned out pretty cool.
Old 02-27-2003, 11:28 AM
This is how it looks...
Craig
Old 02-27-2003, 01:26 PM
clatescivicr clatescivicr is offline
I was wondering which thickness did you use for the cage?
Clate - I'm back
Old 02-27-2003, 01:44 PM
I pretty sure it was 1/8" rod.
Craig
Old 02-27-2003, 01:57 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
I used styrene rod and a candle for my roll cage
Old 02-27-2003, 08:13 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
evergreen have styrene rods???
i thought they only make sheets!
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 02-27-2003, 08:21 PM
Yeah they make L shape piecs too. They have quite a bit of different shapes.
Clate - I'm back
Old 02-27-2003, 09:14 PM
davidmmz davidmmz is offline
roll cages out of what?
Skip using the plastic sprue left over from your models!!!! The scale isn't right. If you're looking for cheap/free plastic tubes, try using the plastic tubes that make up COTTON SWABS!!!! Be aware that some (like J&J Q-tips) are rolled paper and NOT plastic! Get a box of the cheapest generic type -it'll last you for about 1000 models! Plastic cotton swab sticks are identical to Evergreen plastic tubes -but only 3 1/2 inch lengths and 1/10th the cost!!!!
Questions about 93' 300x customization. Dirtycabin 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 12-05-2010 01:21 PM
Custom Auto Art on Metal Avitech Graphics Graphic Manipulation 0 07-03-2010 01:27 PM
Custom Camaro 1969 EtienneArt Sketching and Drawing 0 01-08-2010 11:55 AM
Custom fridge magnets, car magnets, business card magnets- Australia fridgemagnet Graphic Manipulation 0 03-09-2009 01:20 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 06:49 AM
