Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-01-2008, 09:00 AM
ldarmoore ldarmoore is offline
Post Camshaft Position Sensor
I have a check engine light that is on. When I am driving at highway speeds the car stutters. I had a diagnostics done at a parts store. They told me that the check engine light is on because of the camshaft position sensor. Can someone tell me where this sensor is located. If possible does anyone have a diagram or a photo of the location of the sensor?
Old 03-02-2008, 10:39 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Camshaft Position Sensor
Welcome to AF.
What car-year-make-model and engine do you have ?
With out that important info we cant say for sure.....
1999 Grand Am SS 3.4 OHV
Old 03-02-2008, 11:26 AM
It is a 1998 Oldsmobile Cutlass GLS.
It has a 3.1L V6
Originally Posted by xeroinfinity
Welcome to AF.
Old 03-02-2008, 12:05 PM
Thumbs up Re: Camshaft Position Sensor
It has a 3.1L V6
It is on the front of the engine block.
This link shows you how to test the Cam sensor, and replace it.
http://www.automotiveforums.com/vbul...d.php?t=663359
Says Grand Am but it covers your 1998 Cutlass.
Old 03-29-2013, 03:40 PM
crest33 crest33 is offline
Actually, the camshaft position sensor on a 1998 Olds Cutlass 3.1L is behind the power steering pump. Under it. It must be removed first. Sorry. Only the electrical plug-in connection is on the front of the block for ease of testing. You may use a multimeter and wire probe on this connection to find out if you have the proper ground and voltage, as stated elsewhere. But in order to change the actual sensor, you must remove the power steering pump.
Old 03-29-2013, 06:54 PM
maxwedge maxwedge is offline
A990 racer
Welcome to AF, good info but check the dates before posting, this has been dead for 4 years. Thanks.
The Following User Says Thank You to maxwedge For This Useful Post:
xeroinfinity (03-30-2013)
