Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 02-29-2008, 11:25 PM
RCMakita4 RCMakita4 is offline
HIDs Questions?
ok i want to get a set of HID lights on my car. I would like to have both high and low beam if this is possible. My lens on my headlights are real shitty looking right now and i plan on wet sanding and cleaning them up. Is this a good thing to do or doesnt it work to well? Also i wanted that black tint look to my lens. How do i achieve this? Do i paint the back inside of the lens with a black paint or something? Also do i need to buy a set of bulbs for high beam and then a set of low beams. So that would mean id have to get a set that are 9006 and 9005 hids. I have a 98 eclipse gs. And then if i want to do my fog lights just repeat the process which i think they are h3s? Some people said i cant get my high beams in hids cause they use to much voltage and it wont work or something? Is this true?
thanks for the help
Old 03-02-2008, 10:16 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: HIDs Questions?
Welcome to AF.
Look in the tech articles, I did a write up about wet sanding headlighs. Turns out really well. Also you CAN NOT put HID bulbs in your stock headlight housings. These are diamond back housings and it will scatter the light everywhere and you will blind everything. If you really want HID lights buy the ebay projector housings and put HID bulbs in those. There is also a write up on that as well.
I would not recommend you tinting your lenses either. Anything you put on the lens will hinder the light output. However the projector housings are not chrome like the stock ones so they look blacked out somewhat.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-22-2008, 02:17 PM
scals37's Avatar
scals37 scals37 is offline
Re: HIDs Questions?
i need replacement bulbs for these http://cgi.ebay.com/97-98-99-ECLIPSE...QQcmdZViewItem
what size, what kind, and where do you think i should get them
never had to replace them before
1995 Eagle Talon Esi "I shall call her Eileen"
Old 03-22-2008, 08:02 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: HIDs Questions?
Those are almost the same as mine... Your best bet would be to just pull the bulbs and head to Autozone or some place of that sort and match it up inside the store. If you are still unsure of which ones you need, somebody that works there will be able to help you find the right bulbs for it.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
