Old 02-29-2008, 09:02 PM
Traffic Hank Traffic Hank is offline
98 Suburban Help!!!
I had my fuel pump go out two weeks ago and I replaced it and the fuel filter. Now the truck will not idle, I keep on getting a OBDII code P0300 random missfire. I have changed the plugs and wires with no help. I was told that it could possibly need throttle position sensor and or it could be a bad fuel pump. Any helpfull suggestions would be greatly appriciated. Thanks Traffic Hank
Old 02-29-2008, 09:08 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: 98 Suburban Help!!!
you may need to bleed the fuel system although it's unlikey.
Seatbelts Saved My Life
Old 02-29-2008, 09:23 PM
Thanks for the thought but I did that when we tested after the install. Thanks
Old 03-01-2008, 05:35 AM
UncleBob UncleBob is offline
AF -Advisor
there's no gas engine that you need to bleed the fuel system on. single line setups, such as the dodge's, they self purge rapidly. Two line setups, such as the truck in question, purge pretty much instantly
random misfires can be caused by many things. If its the only code, I would suspect a bad coil or cap/rotor issues. Clogged cat converter
There's a list for yah anyway
TPS would set a code
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-01-2008, 12:47 PM
am in the process of new plugs wires and rotor cap- thanks those were my next thoughts also-I'll let you know Traffic Hank
Old 03-01-2008, 09:23 PM
Thanks for the input UncleBob. It was a good try but after changing out the cap and roter it still has the same problems.
Old 03-02-2008, 05:32 AM
AF -Advisor
check the cat?
Old 03-03-2008, 07:35 PM
MobileMom MobileMom is offline
Cool Re: 98 Suburban Help!!!
Try running some fuel injector cleaner through the system. Clogged fuel injectors can cause the P0300 code, and random misfires. If the fuel injector cleaner doesn't quite do the trick, you might to take them out and clean them, or have a shop rebuild your injectors.
Clogged fuel injectors can cause most of the symptoms of bad spark or bad gas issues.
Another thing that you might want to check, is your EGR valve. If it is not circulating properly, it will cause all those lovely problems as well.
I hope this helps!
If your looking for more information, check out
http://www1.autozone.com/UseCase,S00...tInTheZone.htm
or hit me up on my page at http://www.myspace.com/acceleratedautomotive
