Go Back   Automotive Forums Car Chat > Mitsubishi > Legnum
Old 02-29-2008, 04:27 PM
mcrcr mcrcr is offline
Faulty clock - how do you remove it ?
Does anyone know the trick for removing the plastic cover on the top of the dash that houses the clock ?
I have tried to lever it off but it's impossible to see how to release the clips that hold it in place.
I'm sure it has those clips that break unless you use exactly the right technique to remove them.
Thanks.
Mark
Old 09-23-2008, 05:19 PM
nick mann's Avatar
nick mann nick mann is offline
Re: Faulty clock
just lever it some more. There are four clips holding it down - it lifts vertically. Be careful around the smoked plastic, cause that will break! Re-solder the joints on the circuit board from the loom connection pins - that will almost certainly solve your problem.
