Left engine on in park for about 30 minutes, then pulled away and less than a minute later it dies. Will turn over but just wont start. Anybody have any ideas what it might be???
Re: 95 Cirrus Help
Does it have gas? if so you can try anad spray some b-12 in the intake.If cranks when you spray the b-12 then it could be your fuel pump!!
Or if it doesn't start after spraying then it could be your distributor! The latter happened to my 1995 Cirrus and the distributor was gone , no good!!!,so I had it replaced and I replaced the wires and Plugs!! Everything worked fine after that!!!! Good luck I hope this helps!!!!!!! |
